Wagstaff Extra 300
Pull-Pull is the way to go UNLESS you need tail weight. No one has a plane done yet that I know of with gas. I would not cut the rudder servo covering and completely build the plane. Mount your engine and see what you need. If you end up needing 8 oz of tail weight then add the two rudder in ther tail. If the CG is close go pull-pull. That is what I am doing.
Chris
