RCU Forums - View Single Post - Wagstaff Extra 300
Old 10-18-2002 | 10:40 AM
  #219
rcflyerjoe
My Feedback: (16)
Default Pattie W Extra
I have finally flown my plane. This is one beautiful plane. I have a BME 50 on it. I had some radio problems when running the engine at first. I tried everything I knew to solve the problem. I had the ignition on the engine mount box, the batt in the same place. The radio equipt was mounted behind the canopy. the batt is in the tail behind the rudder servos. I could not seperate the equipt any further. Anyway I solved the problem by putting a BOUSH cap ignition on the s[ark plug. I added 1 oz of weight to the left wing for lateral balance. I used all the hardware that came with the kit. I also used 4 Hitec 605 servos in the tail. The plane is slightly nose heavy. I like mine that way because I am not going to fly 3D. I am not brave enough to fly this plane like it was designed to fly. If anyone reading this post thinking about buying this plane, don't delay. This plane flys like *****cat and will fly like a tiger if you want it to. I love it. Landing is very stable. I had a few dings on the kit when I received it. I had no problems with the wing tube. The center section of the horiz stab was too loose fitting so I had to do some filling in where tje stab section was epoxied to the fuse. The kit is not perfect but hell, I'm not either. YOU GODDA GET CHEW YOU ONE!!!!!!
