RE: Senior Telemaster
Bo
Great pictures - so once you have your holes drilled the stab and the rudder fin are not glued together and the stab is not glue to the fuse? So the rudder and the stab are all covered separately and are only held on with the bottom screw? Are you able to apply enough pressure with that one screw to hold the rudder and elevator in place? Sounds great. This sure would make it easier to change out the rudder if you need a larger one or as you said if it is damaged. I have a Challenger and the tail assembly is held on with two threaded rods that go through the tail and holds it on very well from the bottom side with nuts. I am getting ready to order one of the Senior Telemasters to build. And I would like to know if you or anyone else has drawings or pictures of how to make the telemaster wing into three pieces. I have a problem of transporting an 8 foot wing. Also has anyone built the wing in more than one piece without the use of wires on the outside? I want the wing to look like one piece once it is attached to the fuse. I have enjoyed reading this forum. Great assistance and ideas - keep it coming. CARPER
