RCU Forums - View Single Post - Wagstaff Extra 300
Old 10-22-2002 | 01:21 AM
  #257
sicko69
Default wagstaff 300 with a 3250
well finally got the tiger to run great pulls like hell turns a 18/10 at 8500 on the ground will try a 20/8 to get the rpms down to 7200 no over heating ether on 10% wildcat 80/20mix the only problem is the the hole thing weights about 15lbs ready and will need to put 12/15Oz's of lead to balance on the factory cg witch seems a little conservative to me any move it back at all and was think of a bme if it cant 3d with this set up but i get about 20lbs of thrust with the 18/10 the 20/8 should get more any in put would be get
