RE: How can I bend this piece of balsa?
Thanks for the help.
Yes it is a Skyraider Mach II. I've got the deck well supported, and will be using a different canopy.
My first Mach II, I modified into my "Mach III".
This one, I'm going to make into my "Machstang".
I'm almost finished with the rounded wing tips, I'll also be adding a scoop, the extra wing parts at the root(Have no idea what there called, wing fillets or something), and slightly modifying the tail feathers.
I just need to figure something out with the gear. I'd like to do retracts, but probably can't with the wing and retract placement with the CG. I think I'd have a lot of nose over's.
Here's the Mach III
