Some help please,
I have chosen a ASP 120 to put in my next plane, It's my first 4 stroke so I need some advice.
I need to know the best fuel TYPE AND MIX for runing in and genral operation.
I am aware that most who run 4 stroke engines will have a prefered make, what I need to know is composition and %.
It would also be handy to know what glow plug, ideal prop size would suit for gensal use and any specific tips for starting,initial runing in and genral use.
BTW, the engine is going in a WM Groovy 90 3D. It will be set up on LOW rates until I get used to the plane
So top end performance is not the issue, reliability is though.
Some of you may say read the instructions, I would but they will be in Chinese.
I forgot to mention, It will be inverted as well,
