RCU Forums - View Single Post - Wagstaff Extra 300
Old 11-22-2002 | 01:43 AM
  #671
AndyF's Avatar
AndyF
Default Wagstaff Extra 300
Originally posted by KabarAV8
Andy,
Tailwheel looks great! I was wondering if the pre-bent version on Tower would work(bend angle), or if I should get the straight one? Also you mention you used the 9-18 pond version. I saw that Tower has a 1/4 scale version as well. Any info on that? Thanks
I think the 1/4 scale version is actually too big for this plane too wide too stout (I actually used the pre-bent version on my 105" Bud Nosen Citabria). The problem with this one that I could see is that the angle is wrong and does not match the stock tail wheel. I guess you could use it if you wanted to but I felt that it would raise the tail and make it unnaturally high.
Andy
