RCU Forums - View Single Post - Wagstaff Extra 300
Old 11-22-2002 | 01:03 PM
  #674
SMALLFLY-'s Avatar
SMALLFLY-
My Feedback: (19)
Default Wagstaff Extra 300
I thought the aluminum spinner was a little cheesy myself but After 16 flights and 1 broken prop it is holding up fine. I did have to grind it out for the 22" prop. Nothing at all wrong with the stock tailwheel setup either so far. I assume you could drill out the support arms on the stock spinner and use a prop shaft nut to screw the spinner into if you really wanted to do that
