RCU Forums - View Single Post - DA50 Choke modify?
Old 04-01-2005 | 09:03 PM
coony2787's Avatar
coony2787
My Feedback: (33)
Default RE: DA50 Choke modify?
Take the screw out that holds the choke plate on. Then remove the choke plate. You can now pull the rod out that actuate the plate. There is a ball and sping that mkaes the choke lock into place. Romove the ball and spring and then reassemble without the ball and spring. I hope that helps
Chad
