RCU Forums - View Single Post - What engine makes the lightest conversion?
Old 04-02-2005 | 12:14 AM
mikenlapaz
Default RE: What engine makes the lightest conversion?
jpr72c
It you trust your prop hub to be true, this should workd for you. It has for me.
The cut0ff wheel are ablative and do not load up with metal. 4" are best if available.
(edit: Misread your objective, thought you just needed to shorten the fins not reduce the diameter to make a spacer/ hub.)
