RE: Some advice on my first 4 stroke
Do check the valve settings, even before the first run as I've seen new out of the box units miss adjusted. Check them again after the first 20 or so minutes of running as initial wear can make quite a change. After that you only need to check them after several hours of running or when you notice a change in power output or starting problems. Bad valve settings can cause many types of problems, some could cause permanent engine damage.
