RE: difficult incidence
I've been putting the wing on and taking it off all day - while fiddling with those adjustable saddles - and here's what I've finally come up with:
starboard wing: 1-3/4 degrees +
port wing: 1-1/4 degrees +
Sadly when I get to this point and I take the measurement from the wingtips to the floor I get a half inch difference.
I imagine there are lots and lots of happy Hog owners with inacurrate incidence like it and worse. What do you think will happen to this bird if I let it go as is?
If you'll look to the right, you can see how high the dowel hole is and, consequently, how low the wing had to go to get close to the correct incidence.
Dave
