RCU Forums - View Single Post - Which Glue, and Where
Old 04-03-2005 | 04:28 AM
Daryl_y
Default RE: Which Glue, and Where
I try not to use epoxy it smells bad its messy any heavy. I use thin/ thick CA and Titebond. A couple of my planes don't have a drop of epoxy on them as firewalls tailfeathers and landing gear blocks were all glued with Titebond. The trick to use alphatic resin glues is to put a thin layer of glue on both surfaces and let the set apart for a couple of minutes then when you stick the together it is pretty well stuck and drying time is really only a few minutes. Another trick: if you have a perfect fit and your fins will be supported with fillets your tailfeathers can be glued with thick CA. set the stab where you want it push a couple of pins through the stab and into the fuse, slide stab up on the pins just enough to get glue on the surface, slide the stab back down on fuse and remove the pins about 30 seconds later and you are done.
