Originally posted by T. Gardner
Lunatic,
Are you sure you are ready for 3D? The pics seem to tell you may be in over your head. There must be a hundred references about control horns in the last 5 or six pages. The stock ones work fine. But that would be to easy. Good luck. (:
Using Rocket City ball links and standard GP control horn with the push rod in the upper position I get less-than max deflection even with long dubro arms, therefore, I would probably need a different horn. First thing I need too do is fly her than worry about 3d later. Would like too have the max throws installed now on a 2 position switch then deal with all the changes later.
Would that be to easy?
