Wagstaff Extra 300
[QUOTE]Originally posted by bodymann
[B]for those that are having a hard time on how to mount the cover over the landing gear. i just drilled and taped a 1/4 20 wing bolt thur the center of the landing gear and a slightly larger hole thur the cover.
Here my 2 cents worth...
I used socket head screws to hold the gear down. I pressed the cover onto the bolts, hard enough to leave an impression in the balsa. Then I drilled out the impressions with the proper sized drill bit and monokoted it in place. Works like a charm. If I ever need to remove it all have have to do is cut at the seam.
Andy
