RCU Forums - View Single Post - Wagstaff Extra 300
Old 01-12-2003 | 01:44 PM
  #1185
John Murdoch's Avatar
John Murdoch
Default Freebaby - Try This
Dual Elevator Servo Set-Up
Now we will set up the elevators, so that we will have channels 3 and 7 working together. You will plug the right elevator into channel 3, and the left elevator into channel 7. Press the up key till you get to mix 5 or 6. We will use 5 or 6, as they are including mixes, meaning the elevator trim lever will operate both channels. If you do this mix on any other mix, the elevator trim will not work the second channel. Press the + key and change the first channel until it says elev. Press the channel key over to the second channel. Press the – key to change the second channel to SPOI. Make sure that beside SW: it says ON. If not, press the select key till the arrow points at SW, and press the + key to make this say ON. Press the select key till the arrow points at Rate: and make the percentage 100% by pressing the + key. Then move the elevator stick, and the arrow will move to the 0% in one direction of movement. Make this 100% also with the + key. Now we have the elevator working on both channels, but the aux 2 knob will operate the second channel. To eliminate this, will use another mix. For this mix, I would use mix 3. Press the DN key to get to this mix. Once at the mix, press the + key till it says SPOI for the first channel. Press the channel key so that the second channel is underlined. Press the + key and make the second channel is SPOI. Then press the select key till the arrow points at Rate. Press the – key till it says -100%. Then rotate the aux 2 knob, which is on the top left hand side. Rotate this until the points at the 0%. Press the – key till it says –100% also. This completes the set up of the elevators.
At this point, we have a fully functional set-up, but there are still lots of features you can add. You will of course need to set up your sub trims, servo reversing, and travel adjustments as required. Keep in mind that the lower sub trim value you use, for the most part, the better off you will be when trying to use large travels. If you use too much sub trim, your servos will reach the end of their movement before the surface moves very far.
Hopes this helps,
John
