RE: Revo Dismay
hey if youre having problems with the carb, either you got a dud, or you havent been doing after run maint.
i do it after every run, no matter how long the truck is gonna be sitting. Pull the plugwire & drop some after & WD 40 in there, then run the EZ Start for 2-3 sec and then do the same with the carb and repeat. this should keep u running very smoothly, ive found that response is also better when WD 40 is used.
