OS 70 Midrange Needle Setting Freya
I read a post about setting up this engine with the Midrange needle completely closed
I have 800 rpm indicated at fast idle (futaba govenor) 1 3/4 Main needle gives a rapid T/O and transition.
any lower idle gives a cut out on rapid throttle opening
New OS No 8 plug 10% Nitro
Where should I set the Midrange needle now - can I run with it closed ??
1 turn gave me cut outs
Head Speed set at 1500-1600 gives me a shake free ride
All these problems started with cut outs opening up from from fast descents (with lots of unpleasant low level downwind autos)
BTW I have 4 OS 30 Heli - OS 30 and 52 4 stroke
which I never have had to adjust more than one or two clicks between summer and winter for steady light smoke
Martin
