Phil,
I was running a Futaba Super 7 with 1024 PCM RX, dual 1500mah NiMH batteries on dual JR heavy duty switch harness'.Servos were Hitec 5645's all around and an s148 on the throttle. And I was running a Moki 2.10 with
remote glow driver . The TX/RX combo was flown on another model earlier this year with no problems. The model acted as if control was intermittent it would be on its own and then suddenly I had control and it tracked beautifully, this repeated but as I said I got it around to short final when it went uncommanded nose high (65deg.) at idle and stalled. UGLY!!!
Wow just finished reading these posts started on Sunday. I have Patty, got her at the LHS. I have two g62s and would like something smaller if some one is looking for a nib G62, I would trade a new ST G4500 and a new G62 for a 3w48 or some thing close a bme 50 maybe. Any way I have been sanding away at the so called tubes and am getting a fit. thanks to all the work by others I will do all the mods and improvements before I fly.
Ref the last crash. Last year i built a 1/4 scale sig cub put saito 180 with on board glow.
glitch city took it out everything was ok after that.
When Will Andyf fly? that is the question???
