RCU Forums - View Single Post - Wagstaff Extra 300
Old 02-04-2003 | 09:41 PM
  #1497
rcguy1
Default Wagstaff Extra 300
You have about 1/2 inch of balsa in the wing and tail section to hold the 3/16 Robart hinge points. This is plenty for I have 49 flights on my Patty with this setup and have had no problems.
I used two Hitec 5625 digital servos on the rudder with a "Y" harness and never had a centering problem. Just take your time setting up the system.
I believe the supplied control horns are fine.
Last but not least, I don't believe you need two battery packs and switches for the receiver and servos. Just check the battery voltage before you fly and use a good heavy duty switch. But if two battery packs make you feel safer in the air by all means go for it!
