RE: NEW QUEST
The end result is not good. To get this thing to balance I have had to add so much weight to the nose that the plane now weighs over 10lbs. This is with a ST 90 on the nose. I tried to keep as much weight of the rear as possible.
Is the cg right in the manual? It says 165mm and I assume that is measured next to the fuse.
Any sugustions?
