RE: H9 Extra 330L engine
Well I think I'm definitely going to go with the ZDZ as well on the H9 330L. However I'm going to be using the new Hitec Titanium servos in the wings and Hitec 5945MG everywhere else. I'm guessing the plane should balance out with the ZDZ if I carefully position everything.
What did you guys do with the floating tail tube. I've heard these have a tendency to fail as well. I think I'm going to take the "float" out of it and ProBond it into place so it fits equally into each stab.
The other modification I thinking about making is running two bolts into the root of the wing from the inside of the fuse instead of using the set screw into the wing tube from the top of the wing. Anyone done this yet?
