RE: AMD Hawk.
Sonnich
I am going to copy your rudder / elevator installation on post 71 (with your permission of course). It looks like you have passed a long cap screw through the elevator control unit and then used a piece of brass tube as a spacer between a ball joint which connects to the push rod /servo arm, and then a nut secures the whole assembly, is that correct?
There does not seem to be all the hardware to form this unit so I take it you have made up your own.
The instructions are a bit sketchy about this assembly.
John
