RCU Forums - View Single Post - Wagstaff Extra 300
Old 03-19-2003 | 11:35 PM
  #2402
JAG Aircraft
Default Re: Stand offs cheap about a 2 dollar
Originally posted by swift bill
This is how I secured the standoffs on my GP Extra 300s. I drilled and tapped k&S bar stock 1/4 by 20 on one end and 10/32 on the other. I cut two pieces of 1/4 ply to span the top and bottom holes in the fire wall, then drilled 1/4 in holes where the standoffs go. I inserted the 1/4 20 bolts in these hole and secured them with liquid weld. I then placed them in the holes in the fire wall from behind. The stand offs are now screwed to the Bolts with locktite blue. This, I think added some strength to the fire wall and not much weight. Slow epoxy should work as well as liquid weld.
Swift Bill
How much did you have to pay that guy to use his pictures. I saw your and your dog on a picture the other day. Theres no way that youny man in this picture could have got that ULGY in 33yrs.HA!HA!
Have a Good day up there on top of the world and watch out for incoming rag heads. Our TROOPS have got them running you keep them from coming in up there and we will stop them on the bottom down here. Ithink the largest sand storm that been recorded in the world will be takes place in a few hrs.
Have a Good day
James
