ORIGINAL: newbtoRC
Thats good. Loops are fun. My first day flying with my plane i did 5 back to back. Then again i had the support of a buddy box. When you get a little better, try doing an aileron roll at a good altitude. Trainers are hard to do them with, but if my plane if flying right it will do it.
Just make sure that your plane is in a 45 degree climb. The roll rate on trainers is slow and you lose altitude quickly. The climb lessens the effect until you start learning to use down elevator in the inverted part of the roll to keep the nose up.
