Originally posted by Tango
Hey Jack,
I have a BME 50 also. The pictures of the cowling are great!
What tool did you and your brother use to make the cuts for the cylinder head, muffler and adjustment hole.?
Steve
He used a dremel also.
While the cutoff wheel will work well. The sanding drum is what he used to cut the opening and finish it. Before seeing him do it this way, I would have used the cutoff as well, but after seeing how easy and nice a job he did just using the sanding drum, I won't use the cutoff on a cowl again.
If you tip the dremel on a 45 degree angle from the surface your cutting, you can run the sanding drum right into it without having to create a starter hole. Jut tip it on a 45 and pull the whole dremel downwards. Not pushing down like if you were drilling, but sliding down. Don't be to near an edge though. Stay in a little ways in case you goof.
Mark the area you want to cutout with a black magic marker and when you do the initial cutout, don't try to go right up to the line. Stay about an 1/8th of an inch away from it until you get the piece out.
You might want to put a drop of CA glue on the cut edge of the gold stripes. It peels back easily at any openings.
Jack
