RE: Where do I exit the fuel lines?(4* .40)
If you are using standard fuel line you will need to drill 1/4 inch holes and force the fuel line through the holes. Drill them side by side even with the fuel intake on the carb. Just make sure not to push the tank in to far so as not to pinch the lines. Install foam to protect the tank from moving forward during normal flying. Good Luck, Dave
