RCU Forums - View Single Post - Help with this reverse pitch stuff
Old 04-07-2005 | 11:00 PM
bdavison
Default RE: Help with this reverse pitch stuff
Do any of you know if you need a heli radio for using the "collective" er ....reverse pitch, or is it simply a "flip a switch for reverse" mode.
Seems like a collective type set-up would be more desirable, as you could maintain a constant motor RPM and just adjust pitch for thrust. Would probably look really cool on the ground too, as you'd have a run up, and then INSTANT thrust for a snappy takeoff with a collective type varient.
