RE: Aileron Servo
my bad, guess I should go back and read the original post first. It's been a while since I read that first post, and we all go off on dual servos, so on.
You can use EPA to adjust total throw, but not differential. That HAS to be done mechanically with a torque rod setup.
The heat shrink tube idea is a great one. I will use that one when I use dual channels!
