RE: Are 'Evolution' engines any good??
Tying the model down and letting it run for extended periods on the ground will ruin any engine.
If you were able to do so, you would see a very fine cloud of dust being pulled from the ground and into the engine's carburetor.
Go to a pattern contest and see how much effort most pattern pilots go to to minimize their engine's running time on the ground. Those in the know will have a drill worked out to keep this time as a minimum. Dust/dirt is abrasive and is similar to running lapping compound through your engine.
No engine will tolerate this kind of abuse for very long without showing a drop in power production.
Years ago, in RCM, IIRC, there was a picture that was taken of a model airplane with running engine at dusk. Car headlights were illuminating the dust cloud as it entered the engine. It changed my behavior around engines permanently.
Ed Cregger
