Widebody 40 Incidence Question
I'm looking for a little help here.
In setting up the wing and Stab of my CA Widebody 40 I've been marking some incidence lines on the fuse and taking some measurements.
I'm using the front part of the fuse top/bottom as level and setting that level above the building board.
Then I'm penciling reference lines on eith side of the fuse by the wing LE and TE and back by the fuse.
What incidence do I want the wings and Stab set up for?
The fuse laser cutting puts the wing at about 1.0 degrees positive incidence, and the stab at 0.
Is this right?
I'm assuming for a pattern ship, I should go for 0 and 0.
Can anyone with a Widebody 40 or 60 help me out here?
Trigger
