RE: Changing from magneto to electronic ignition
Karol,
It is a relatively easy conversion (at least with the CH system, but I expect they are all similar). If you have a a flywheel puller, that process is a dead sinch. After that, install all the ignition components as instructed and then set the timing. Nothing complicated. If you have a spring starter, remove it.
Then, of course, balance the plane after all is done.
Enjoy!
Bedford
