RCU Forums - View Single Post - World Models p51
Old 04-10-2005 | 08:42 AM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: World Models p51
Ask, and you shall receive. Saito 100 running a 12/12 apc. I reinforced the firewall inside and out. Also removed the retracts and slopped epoxy in and around the mounting rail area. When I balance it, I installed the weight inside the rear section of the air scoop.
I also modified the control rod to the elevator basically splitting the wire to each elevator and used 4-40 rod. Its pretty solid plane and flys very well once it gets trimmed out.
By the way, don't get this Miss America color Scheme, Its a pain to keep up with
ID:	256444   Click image for larger version
