RCU Forums - View Single Post - Wagstaff Extra 300
Old 06-05-2003 | 02:30 AM
  #3657
BasinBum
Default Wagstaff Extra 300
RCguy and Jan,
Try programing in Expo on the throttle to have more throw on the stick through the low end.
Did the maiden on on my Patty today! CG 6-3/8" at the root, don't know the weight yet. Jumped off the ground with the Brison 3.2 but needed some down trim.
Inverted I only needed to think about adding down eleveator to stay level, really I just touched the stick twice as lightly as I could for half a second to stay level during about a ten second inverted run. I think the CG is perfect for 3D at that point.
Low rates (9/16") elevator looped fairly tight at 1/4 of the stick and ailerons were very responsive. I'll program in expo on everything for next time.
She slowed to a crawl with no hint of tipping.
After only one flight I was very happy I got rid of the Lanier Cap to get Patty. Had engine trouble that turned out to be a clogged carburator filter so didn't get anymore flights in today.
I havn't even sealed the control surfaces yet so it should only get better.
RD
