I had it running fairly well initially but it would only idle with low end screw turned all the way in. Now I can't even get it started.
Have you turned the idle screw back out again? My MVVS 58 is difficult to start if I really lean the low needle as standard practice. I richened the idle screw a tad and all it need is five flips max. Transition is still smooth.
