Originally posted by fancman
That's pretty close to the ignition and a potential RFI problem. Have you flown it like that?
I have been flying it for 6 mos. with no problem i use Hitec rec. no problems with RFI on gas and ignition when you use them. Are you can use PCM without problems but FM hitec cost less and work. The guy that test BME engines told me to use them.
Good luck
James
