BME 50 choke
BasinBum, I like your idea of not having to cut the original arm off of the choke lever, but how did you compensate for the original arm being mounted at an angle evidently designed for manual push-pull operation from an angle that is 90 degrees to the crank, rather than with it, which is direction a servo would push/pull from? Do you have any pics of your choke arm setup at the carb?
Thanks....Martin
