ORIGINAL: scott14
mglavin,
Thanks..... would I then need to purchase servo adapters from futaba "J" to hitec/"Z"?
You can purchase the Hitec/Futaba RX with the "J" plug feature if your TX is shift selectable and or some of our RX's have universal connector slots, simply specify your needs when ordering. Otherwise you could simply remove the "J" tab from the Futaba servo and plug and play with a positive shift RX.
