Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Which Receiver
Old 04-11-2005 | 11:47 AM
scott14's Avatar
Default Which Receiver
Please help...
I bought a plane with Futaba servo's and no receiver.... I currently use an Airtronics VG6000 Transmitter. I would like to use a Hitec receiver, since I plan to use Hitec stuff in the future.
Do you have a receiver (6 channel) that will work with the futaba servo's and Airtronics transmitter?
Scott
Old 04-11-2005 | 12:43 PM
My Feedback: (31)
Default RE: Which Receiver
Hitec has several offerings for your needs. Request an RX for either JR or Airtronics (positive shift PPM/FM) equipment as they utilize the same modulation shift. However I believe the 6000 is capable of shift selection, in this case either positive and or negative shift RX's will work.
The Electron 6ch or the Supreme 8ch dual conversion RX’s would suit your needs.
Old 04-11-2005 | 12:46 PM
scott14's Avatar
mglavin,
Thanks..... would I then need to purchase servo adapters from futaba "J" to hitec/"Z"?
Scott
Old 04-11-2005 | 01:01 PM
My Feedback: (31)
ORIGINAL: scott14
mglavin,
You can purchase the Hitec/Futaba RX with the "J" plug feature if your TX is shift selectable and or some of our RX's have universal connector slots, simply specify your needs when ordering. Otherwise you could simply remove the "J" tab from the Futaba servo and plug and play with a positive shift RX.
