Wagstaff Extra 300
Anyone have troubles yet using the stock tank for Gas? I picked up a Dubro Gas stopper but I don't know if it fits the stock tank yet......... Also in regards to the Canopy...... Are you guys re-enforcing the shield to the frame or just the mounting of the whole unit....... I have a dowel pin in the front and a connection on each side..... Should I leave the dowel alone and just install 4-40 threaded inserts on the bottom lower rear corners? I am unsure of the exact issue........ the shield to the frame seems rather strong.........
Thanks in advance
