RCU Forums - View Single Post - NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Old 04-12-2005 | 04:59 PM
nemesis4u's Avatar
nemesis4u
My Feedback: (77)
Default RE: NEMESIS4U's SHERMAN FULL FUNCTION BUILD
OK GANG....Here are lots of parts After getting coats of FLAT OLIVE DRAB Paint applied...Lots of Sprues...It is easier to paint these on the sprues before assembly then once assembled you may touch up the areas that need it...gives a better look than painting after assembly.. Just my opinion..I did the opposite on my KingTiger as I made several subassemblies then painted those parts and then assembled everything...Not bad ,,,but on my Pershing I painted the pieces ON the Sprues ,Then assembled everything as I am doing on this SHERMAN and it went MUCH smoother.... so here are the parts on the SPRUES and also the Turret, upper Hull and assemblies...
ID:	257460   Click image for larger version
ID:	257461   Click image for larger version
