Eclipse 7 flight conditions and idle RPM settings
I would like to have different (higher) idle RPM in different flight conditions with the Eclipse 7 in ACRO mode. I have activated flight conditions and programmed D/R and Expo for all of them. But the throttle trimm is working only in NORM mode. In ST1-2-3 the throttle trimm does not work. Can you recommend some work around?
