RCU Forums - View Single Post - Twist 3D... What Engine???
Old 04-14-2005 | 11:48 AM
thevirginian
Default RE: Twist 3D... What Engine???
macguyver77;
If you going to get a Saito82, which is fine, although way too much power, you definetly don't need a vibration mount. Break in your Saito in the air. Perhaps, run one tank thru on the ground with the factory settings and then go flying. The only thing you need to adjust is the low end. Otherwise you will not get a reliable idle on the ground. Use a 14x4W APC and fly half throttle, at the most. You'll find out really quick, how much power you'll have. Good luck and have fun!
