RCU Forums - View Single Post - Suggestions PLease
Old 04-14-2005 | 06:13 PM
Nhill527's Avatar
Nhill527
Default RE: Suggestions PLease
I Can Use This One Rite ??
Usage: Air
Channels: 6
Modulation: FM
Frequency: 0
Computerized: Yes
General Specs:
- Trainer Mode: Both
- Mode Select: Yes
- 8 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
- 6 Channel Servo Reverse
Special Functions:
- 2 Mixes
- End Point Adj.
- Dual Rates
- Limited Exponential
Display Warning:
- LCD Display
- Low Battery Warning
- Timer
Applications:
- Electric Helicopters
- Standard Airplane
- Standard Helicopter
Acrobatic Functions
- Aileron Differential
- Flapperon Function
- V-Tail Function
Helicopter Functions
- Gyro Program
- Idle Up
- Offsets
- Pitch Curve
- Pitch Trim
- Revo Mix
- Swash Select
- Swash Throttle Mix
- Swash Type
- Throttle Curve
- Throttle Cut
- Throttle Hold
