Suggestions PLease
MS
i just bought a hawk sport,i'm trying to find a control for it,cant really spend over $250 but i want a nice one that aint junk. any suggestions ?
Yes, there would be 5 channels used. But I still recommend getting the Futaba 7ch as a minimum entry functionality-wise.
Have you picked out a gyro to use yet? Some require an additional receiver channel. I know that the Futaba gy401 head hold gyro does, and this is the most commonly recommended gyro for helis in the class your have purchased.
Oh, and I mistypes the link above
brucknerhobbies.com
$169 for the 7CH transmitter only.
brucknerhobbies.com
MS
the helicopter i got came with a GY401 Gyro and it has a high speed digital rudder servo in it already. so all i need is 4 servos ?, towerhobbies has a flight pack for heli's. im looking at this control but imma need servoes and a reciever to,any good flight packs to work on this ? im new to helicopters. http://servocity.com/html/7ch_transmitter.html ,the $169.99 control.
VA
In your price range the JR6102 is a good radio that will serve you well. It includes a full radio system as well.
http://www.horizonhobby.com/Shop/ByC...odID=JRP6644**
MS
if i could use a 6 ch control then hobbypeople.net has a Airtronics VG6000 with 4 servoes for $174.44,its in there book i have,
its for heli also, http://www.hobby-zone.com/airtronics.htm or this one http://hobbypeople.net/gallery/755493.asp .. a 7ch is WAY to high for me right now, can i get a 6ch to learn on and upgrade ?if i like this heli then im pretty sure ill end up with another next and can just use the extra control on it... im also wondering about something to deal with the heli's lift. i have had a micro heli and when i give it trottle it lifts automaticly.. does the gassers do it ?.. the reaon im asking is i had a sim for rc's i forgot the name,but the heli would not lift off the ground as i gave it trottle,the engine just gained RPM and i had to push up on another stick to make it lift off the ground. maybe thats not to confusing lol
i confused my self.
i confused my self.
I know most guys here a partial to Futaba, the small group of guys I fly with all use Futaba radio's. But for about $150-$180 you can get a brand new JR XP6102 on ebay...I cant remember the guys name but he sells a ton of RC stuff with really good feedback. His prices fluctuate a bit but I got mine new for $149 "Buy it now" with the warranty. This is my first transmitter, is very "beginner friendly", and already has 2 helis and 5 planes programmed on it
MS
I Can Use This One Rite ??
Usage: Air
Channels: 6
Modulation: FM
Frequency: 0
Computerized: Yes
General Specs:
- Trainer Mode: Both
- Mode Select: Yes
- 8 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
- 6 Channel Servo Reverse
Special Functions:
- 2 Mixes
- End Point Adj.
- Dual Rates
- Limited Exponential
Display Warning:
- LCD Display
- Low Battery Warning
- Timer
Applications:
- Electric Helicopters
- Standard Airplane
- Standard Helicopter
Acrobatic Functions
- Aileron Differential
- Flapperon Function
- V-Tail Function
Helicopter Functions
- Gyro Program
- Idle Up
- Offsets
- Pitch Curve
- Pitch Trim
- Revo Mix
- Swash Select
- Swash Throttle Mix
- Swash Type
- Throttle Curve
- Throttle Cut
- Throttle Hold
Usage: Air
Channels: 6
Modulation: FM
Frequency: 0
Computerized: Yes
General Specs:
- Mode Select: Yes
- 8 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
Special Functions:
- 2 Mixes
- End Point Adj.
- Dual Rates
Display Warning:
- LCD Display
- Timer
Applications:
- Standard Airplane
Acrobatic Functions
- V-Tail Function
- Gyro Program
- Idle Up
- Offsets
- Pitch Curve
- Pitch Trim
- Revo Mix
- Swash Select
- Swash Type
- Throttle Curve
- Throttle Cut
- Throttle Hold
Sorry cant remember his ebay name...but I did a quick check and found a new one right away going for $160 "Buy it now" If you not in a huge hurry and spend some time window shopping online you'll find some really good deals. Good luck!
http://cgi.ebay.com/ws/eBayISAPI.dll...68396638&rd=1&
