Originally posted by awood12345
Because I cannot afford digital servos, I am thinking about using 2 standard cheap 102 (sanwa/airtronics) servos for each aileron, and elevator, and 3 on the rudder. This is because the 102's are short on the 60+ ounce per inch mark so if I double them up I'm safe! I think I will put a O.S. BGX-1 in the front too.
If you guys think this setup will fly and prophang, I'll get it.
Thanks Alan
You don't need digital servos, and you don't need to double up on the servos either, just get an analogue servo with the same torque as the digital servo.
