RCU Forums - View Single Post - Broken Differential??
Old 04-15-2005 | 09:26 AM
Da Smak
Banned
Default RE: Broken Differential??
It's possible that there is nothing wrong with the diff. You may have lost the grub screw from the center shaft cup. If you have thrown a gear in the diff though the repair is very easy. I'd cheack your bearings first before you blame the diff. Diffs rarely fail, but if a bearing in the rear upright is on it's way out, then maybe that is the jam.
