somthin extra 3d?
da King,
Basically for the servo installation all I did is square off the holes on the back of the fuselage right a the stabs leading edge, glue a piece of ply wood in flush with the fuse sides (with epoxy) and then a straight linkage setup. The linkages are only about 5 inches Long. The rudder servos was mounted on the bottom of the fuse with a mini pull pull setup. I hinged the rudder with those square plastic hinges with the metal pin in them. I remove each individual pin a replace them with one long piece of music wire. I did this so I can interchange different rudders.
I will try to get some pics if you want but it might take a day or so.
Cap,
