RCU Forums - View Single Post - range : 2 feet
Old 04-17-2005 | 02:59 PM
Rodney
Default RE: range : 2 feet
Yes, sounds like your antenna is disconnected at the receiver. If you can remove the reciever, open it's case and take a good look. The antenna should be soldered to the PC board. Get your local expert to look at it for you. It is easy to solder on a new antenna if necessary.
