RCU Forums - View Single Post - GP Ryan STA
Thread: GP Ryan STA
Old 04-17-2005 | 07:52 PM
  #74
ryanpilot's Avatar
ryanpilot
Default RE: GP Ryan STA
Actually after reading your question again I want to clarify one thing. The wing split between the balsa and plywood ribs (the balsa rib is glued just inside the plywood rib) and you could see where there was glue between them but did not adhear. The glue had dried before the parts had been assembled and only about 10% surface actually glued. The epoxy joint between the two wing halves held great.
